carb screw settings on 19.5 craftsman briggs & stratton motor
got a craftsman rider that all the carb screws are closed whats the stock settings??
Is dit een goede vraag?
robert, this is highly dependent on what engine model you have and what carb is installed. These instructions are for Vanguard Single Cylinder:
"Initial Mixture Adjustment"
1. Turn the idle mixture screw ([A] Fig. 1 2) in until you feel it just make contact with the seat.
2. Back the idle mixture screw out 1-1/4 turns.
3. Start the engine and let run at half throttle for 5 minutes to bring it up to operating temperature.
Adjusting Idle Mixture RPM
1. Move throttle to SLOW.
2. While holding the speed control lever (B) against the idle speed screw, adjust the idle speed screw (C) to obtain 1750 RPM, except as noted for the following models:
• Model 104700: 1500 RPM
• Models 161400, 260700, 261700: 1200 RPM
• Models 085400, 086400, 115400, 117400, 118400, 185400: 1300 RPM
3. Turn idle mixture screw (A) clockwise (CW) until the engine just begins to slow.
4. Turn idle mixture screw counterclockwise (CCW) until the engine just begins to slow.
5. Turn idle mixture screw back to midpoint and release the speed control lever.
6. Install limiter cap (if equipped) using knockout pin (#19135)."
For more precise instructions for your mower, it is imperative to have the engine number, model etc. but I do hope this helps. Good Luck.
Was dit antwoord nuttig?
Figures you reference are not attached
@silverfoxdan what references do you need?
I can figure out which screw is which...just wanted you to know that ifixit did not post the figures if you intended them to be included.
@silverfoxdan yes, I see now what you mean. I think I still have those instructions. I'll be adding them to this as soon as I fine them. Thanks for letting me know. I appreciate that.
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 183
Altijd: 11,983
