Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
4-inch iPhone uitgebracht in maart 2016 met hardware-specificaties vergelijkbaar met de 6S. Verkrijgbaar in Silver, Space Grey, Gold of Rose Gold met opslagopties van 16/32/64/128 GB. Model: A1662 en A1723
Power button won't click
At some point my power button stopped "clicking." I have to press it really hard for it to work at all.
I've dropped this thing several times, so that may be involved, but I can't find anything that seems bent.
I've torn it down to the power button and removed and cleaned it; there's nothing wrong with the button itself. Could it be the Audio Control and Power Button Cable?
Replace the internal power/lock, volume, and the vibrate/ring switches along with the cable and the power contacts for the vibrator. Compatible with 1st generation iPhone SE models. Afbeelding
Product
iPhone SE (1st Gen) Audio Control and Power Button Cable
$28.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Given that there are only two components that could possibly be the problem and you've pretty much eliminated one of them, whatever remains, however improbable, must be the truth (to mangle a Sherlock Holmes quote).
But yeah, I'm with you in saying your next step should be to replace the button flex cable. The thing is, I think you already knew that but just wanted reassurance. So yes, go for it and let us know how it all turns out!
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
There's another component: [The Power/Sleep button bracket}(iPhone 5s aan-/uitknop vervangen). One possible answer is "no, that's not possible; the button flex cable doesn't make it 'click.'"
There's also damage in that area (the back glass is broken), so I guess that could be involved, but I don't see how.
door Deel
@calion42 Well, the actual "click" action is caused by the metal dome on the circuit board. The external button compresses the dome causing it to deform and once it gets past a certain point it snaps down to hit the electrical contact pad on the circuit board; that's the source of the tactile and audible click you hear and feel.
So you do need all three parts in order for it to work; the physical button to depress the dome, the electromechanical dome/circuit itself and as you pointed out, the button bracket that supports the circuit flex. Outside of physical damage, there's not much to go wrong with the button itself and the bracket, but the button flex cable is subject to wear and will eventually quit working at some point.
door Deel
@dadibrokeit That helps, thanks.
door Deel
Voeg je antwoord toe
Calion zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 369
