System ui is not reposnding
System ui not reposnding
Is dit een goede vraag?
If your Galaxy S22 + is showing “System UI isn’t responding” or crashing randomly, here’s a step‑by‑step guide to troubleshoot it.
From Reddit and user forums:
“Deleted the Good Lock app and it stopped … until One UI 7 update… then boot looping during update… after battery died it installed and stabilized” (Reddit)
“Resetting all app permissions seems to have worked for me. Haven’t had the issue since” (Reddit)
In other cases:
Step Action 1. Restart Force reboot (Volume Down + Power) 2. Safe Mode test Test stability without 3rd‑party apps 3. Clear System UI cache Storage → Clear cache for System UI 4. Wipe cache partition Recovery mode → Wipe cache → reboot 5. Remove customization apps Uninstall Good Lock or heavy UI tweak apps 6. Update One UI / Android Manually check for latest available firmware 7. Factory Reset Backup data → Full reset if nothing else helps
If none of the above steps fix the issue, some users found the problem persisted even after reset—leading to diagnosis of a motherboard or storage chip failure. In such cases, repair or replacement may be necessary (Reddit, Samsung Community, Samsung Community).
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 17
