fun running after shut down
i have a hp elitebook that after a shut down the fun continues running and the wireless LED are also not turning off
Is dit een goede vraag?
Get the model off of it and we can offer more tailored advice. It should look like this:
Was the laptop hot to the touch when you shut it down? I have had the 840 G3, G5, and a 640 G9. The only recent generation machines I have skipped is the G10 purely due to price since I can get 2 640 G9s for the cost of one G10, and the MOST I lose is the marginally better 13th gen chips (vs 12th on the G9. But at the same time, it makes for an excellent bargaining chip when a seller has one with the 256GB SSD, for example).
Now that being said, I skipped a few:
My experience is usually with the EliteBooks (especially older models that predate the 11th and 12th gen machines). Those tend to be due to Intel's somewhat troublesome thermal management before the 11th and 12th gen CPUs (ESPECIALLY i7-based units), but the G9 and up with the i5 (and potentially the i7; I do not see them a lot, or they're priced sky high in comparison) may run the fan for a bit to get the system cooled down a bit. It's a protective mechanism done BY DESIGN when the computer is hot to prevent heat damage to the CPU/motherboard/GPU (if equipped). My i5 12th gen 640 G9 doesn't do it, but it's generally due to Intel getting their act together on heat management on ULV chips around this time. As such, this protection becomes less of a necessary evil.
NOTE: Legacy machines with the 8th generation and older will always do this, as will the 10th generation machines to a lesser degree. It's due to the processor's tendency to run hotter on those machines.
The main thing to watch for is the fans shouldn't stay on permanently - if they do, something is wrong with the readings coming from the board, the CPU, or the fan has issues. If it stays on for a few minutes, that's very much normal with the EliteBooks as long as it's only doing it for ~5-10 minutes. Unlike HP Consumer, HP engineers the EliteBooks with some common sense and doesn't design them to bake themselves to death. If you want to confirm this, pull the CMOS battery (and primary battery connection) for 2-3 minutes, plug both back in, and let the BIOS reset. If it continues, it's probably expected behavior, especially on an older unit such as a G7 or older with hotter running chips. If it doesn't, then there was probably something wonky with your BIOS triggering it. That is where I would start, especially if my G9 did it, knowing I have a cooler running machine that does not depend on this.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 39
Altijd: 39
Hi @kevinochieng
What is the full model number of the laptop as shown onthe product information label on the bottom of the laptop?
How hot is the air coming from the fan vent?
How are you turning off the laptop e.g. just closing the lid or using the Windows >Power > Shut down options?
Does the fan and light turn off if you press and hold the Power button for >4 seconds after you have shut it down?
door jayeff
