Ga door naar hoofdinhoud
Repair and disassembly information for Logitech's K830 HTPC keyboard for PC-to-TV control.
USB-C charging port for a Logitech K830 keyboard
My Logitech K830 keyboard, the micro USB port broke off. I am hoping that I can replace it with a USB C charging port. Does anyone know if There is a USB-C port that will fit the PCB board correctly. If not, I will just have to wire in a connection so that I can continue using my keyboard. Thank you for your help.
Is dit een goede vraag?
5 opmerkingen
Thank you for your help and advice. After reading your post it looks like I will just replace the existing port and go out and pick up a USB-C to USB micro adapter. Now I have to look and see if I can find out what micro-USB connector was used by Logitech when they made it so I can try to order a replacement to solder back onto the board. Thank you again for all the information and help you provided.
door
@n200setup If you open it up and take some high resolution photos of both sides of the circuit board and hopefully the front back and sides of the connector itself, we've got some folks on here (myself included) that are pretty good at locating compatible replacement parts. Ideally if you could unsolder the broken port and get us a photo of the circuit board footprint that would help the most, but we can work with the other photos if not.
door
Hello! I came across this post while looking for a solution for my own K830 since I love it annd I never wanna throw it away, and thought I’d come back to add my two cents, since there are several people here saying it’s impossible. After some searching, I found diy usb c ports on Amazon that come with a pcb on the back in the arrangement of micro usb connections and it comes built in with two tiny surface mount pull down resistors. I’ve just put it all back together and it’s working like a beauty… after ripping off the pads on the keyboard pcb due to a lack of hot air desolderer, and having to scratch the traces as a last resort. I’m not sure if I can post a link here, but I’ll give it a shot: https://www.amazon.com/dp/B0DRP5YS5L?ref...
I hope you still have the keyboard and this help you if you haven’t already figured it out by now.
door
Well I wrote a long response and then it got tossed when it made me log in.. the part you’re looking for exists! I just finished retrofitting my K830 today with the help of a pack of diy usb c ports I found on Amazon that have a pcb on the back with soldering pads and pull down resistors, to boot. Not sure if I can post links here but I’ll give it a shot.. chenyang 5 Pack USB C DIY... https://www.amazon.com/dp/B0DRP5YS5L?ref...
Hope this helps you if you haven’t already sorted it out
door
There are now USB C module/ports that match the exact pin out of micro. Search this "USB Connector Type C Female Jack 5Pin SMD SMT Type-C Socket Charging Port for PCB Soldering" and you should find it. (alixpress/amazon)
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I've seen discussions on this subject before, and up to now the conclusion has been that there ain't no such animal.
The big problem is the number of pins; USB-A plugs only use four pins, the USB mini and USB micro have five, while the USB-C connectors have 24 pins! In addition, the fact that USB-C is reversible complicates the whole situation with pins that work differently depending whether you've got it flipped one way or the other.
So it's pretty much impractical to use any kind of existing USB-C cable on a USB micro footprint, and thus far nobody has gone to the trouble of designing and building a port that will fit a USB-C port on a USB micro footprint. Part of the problem is that there are a huge number of different USB micro footprints out there, so any adapter you design will only fit a very small number of ports. My conclusion is that you're not likely to find the kind of converter you're hoping for.
I'd say the next best thing you could hope for would be to purchase a USB-C breakout board and see if it can be mounted on or near the existing port. You'll have to wire from the circuit board to the breakout board, but it should be possible. Here's one example of the kind of thing I'm thinking of; you can find dozens of other ones that may work better for your particular situation.
Of course, you can always just replace the existing port and go out and pick up a USB-C to USB micro adapter like this one.
I'd be curious to hear what kind of solution you come up with, so be sure to come on back and let us know how it all turns out for you.
Was dit antwoord nuttig?
Score 2
Do you still have this problem?
As @dadibrokeit said, finding a USB C connector that perfectly matches the position of the old MicroUSB socket will be nigh-on impossible. However if you can find a small space in the case for a 6-wire USB C female port and a couple of 5.1k resistors, you can make a basic USB 2 charging connection through a new USB C connector on your keyboard.
You can see the socket needs a 5.3mm x 12mm rectangular hole, 14mm deep. You may be able to enlarge the hole for the MicroUSB socket, but failing that - a shallower hole and some hot glue will keep the new socket in place.
Solder the Vbus (red), D+ (blue), D- (white), and Ground (black) wires to the PCB connections for the original MicroUSB port: Vcc, D+, D-, and Ground:
Then "pull down" both the CC1 (green) and CC2 (yellow) wires by connecting each to Ground through a pair of 5.1K resistors.
By adding those two "pull down" resistors, you tell any power supply, laptop, TV etc. connected to the far end of the USB C cable plugged into your new USB C port that you need 5V power on the Vbus lines - which will power up the Vcc line on the old USB 2 interface and begin charging your keyboard. Hopefully.
The socket will still function even if the cable is reversed because a USB C socket has Vbus, D-, D+, Ground and CC(x) pins symmetrically placed on both sides:
This should work - I'll be testing it on another project in the next few days and I'll let you know how it goes.
Score 2
This is what I use for these devices when I have mostly USB-C, especially Apple devices: https://www.amazon.com/Cable-Matters-Mic... -- they sell cables which replace the USB-C end, while maintaining the MicroUSB on the other end of the device.
This isn't a port REPLACEMENT, but it works well on devices which use it like the Epson Perfection V39 and V39 II (which STILL USES MICRO LIKE THE V39 V1 - WTF EPSON? >_<) as a workaround. I'd love to see more devices myself ditch MicroUSB as the port and cable are terrible for longevity, but what I have seen done is dremeling out the case to fit it in a empty area, and then wiring it up to replace the MicroUSB port when they break.
Score 1
Voeg je antwoord toe
N200 Setup zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 105
Altijd: 522
