Sharp 80” backlight error - LED circuit troubleshooting help needed.
Hello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing green led.
> I have 110 volts DC at the LED driver MOSFET and 192 DC volts at the L1 LED string input connection. I found a spec for the LED input voltage of 215 volts. Backlight lights up in Service Mode.
> I removed the front panel and checked the LED strips with an LED backlight tester. I recorded 283 volts at each light strip in automatic mode and all LEDs light up bright. There are 15 rows with 21 to 24 LEDs per row.
> I checked voltages at the FETS on the return circuit. The voltages at the collector pin were 36 volts DC (+ or - 1/2 volt) at every FET. There are 15 FETS, one for each light string.
> This is where I found a peculiarity. I checked the voltage at the emitter of each FET and I also got 36 volts which I would expect … except for 4 FETS all beside each other had double or triple voltages. Three were 70 volts and one had 93 volts. I checked the gate voltages and they all are 5.5 volts except these 3 have 1.5 volts and is one has 18.4 volts. I removed the FETS from the board. There are 4 per heat sink so I removed 8.
> I checked the FETS with a multi meter following an online transistor test procedure. They all checked the same … okay.
Any ideas as to what is going on here and or what my next steps should be????
Thank you in advance. All expert opinions are immensely appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
