The best way to remove the remaining battery adhesive
My Dear Community!
I successfully managed to remove the battery for an iPhone 11 that I am currently refurbishing and saving. My only problem is that after the battery removal there is still very very strong glue on the metal area that I tried to scrap off with my spudger for almost 2 hours and using 99% isopropyl alcohol but I don’t know what am I doing wrong.
Should I keep it soaking in the alcohol and after use the spudger or should I use a different chemical?
Thank you very much for your response!
Is dit een goede vraag?
Have you tried heating it a little with a heat gun on lowest settings?
door dinoo_fixit
Hi there @dinoo_fixit !
I did not try heating it but what I realised is that I didn’t leave the glue in alcohol for too long. The next day the whole area where the battery adhesive was dry and it became easier to scrap it off.
door Lajos Kovacs
@mrkovacs I'm glad it worked :)
door dinoo_fixit
