Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
20 Vragen Bekijk alle
Advice regarding back glass (cover)replacement
Dear Community!
I managed to save a very good iPhone 11 from ending up in the landfill.
There are only two issues with the phone.
  1. Battery is at 75% which is totally fine, I will replace it.
  2. The back glass is cracked on the top right corner deeply and went all the way down and to the camera area as well.
So, I was looking on Ebay for just the glass. I found numerous sellers who make “unbranded” covers. In addition, I found a special tool set as well that would be needed in order to remove the glass. It looks like a knife and you can change the tips to crack up the glass as I saw on videos. For adhesives and for the camera rings I would buy those from iFixit.
The question towards my community is the following: What should I look out for the procedure? What do you use for an easier removal? I know there is laser solution too but as I am passionately refurbishing and saving electronics I want to do it.
Currently I have the following tools that would help me in the process:
iFixit Pro Tech Toolkit, loads of spudgers, iOpener, heat gun, air blower.
Thank you for Everyone's response!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@mrkovacs if you want to do it, it will be hard. i mean, you can follow guides for ex this one: https://www.youtube.com/watch?v=OZ4217kR... but otherwise then that, you can put on a case, but if it hit the camera, then you could replace it, but its way harder then just the back glass. sorry, i dont really know anything else, im not that good lol
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for your kind answer @wyattd ! In the end I found a reliable shop where they repair back glasses and I sent the frame. I am waiting for it now to arrive back and afterwards the refurbish procedure will continue.
door
How do I change my backglass and what glue do I use?
Score 1
1 Opmerking:
Thanks @seppebruyland ! For future repairs I will follow this procedure!
door
Voeg je antwoord toe
Lajos Kovacs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 20
Altijd: 64
