Ga door naar hoofdinhoud
CR2023 Battery not connecting on one side
I've got an issue where the battery isnt getting enough pressure or something on the left side (looking at the + as the top) and so normally wont turn on but it will turn on if i press down on it. is there a way to wedge something in maybe? ill provide pics if asked but i dont know what to photograph to be honest ^^;
Is dit een goede vraag?
1 Opmerking:
Could you hold it with insulating tape as a workaround? And you could start by taking a couple of photos of the battery compartment with and without the battery
door
Voeg een opmerking toe
1 Antwoord
You could probably try using something like aluminium foil that you can find in a kitchen to try and help the battery make contact since it should be possible to use it as a spacer to create more pressure within the battery holder.
You could also try bending the pins within the battery holder to try and force it to make contact with the battery in there.
Was dit antwoord nuttig?
Voeg je antwoord toe
azurejpg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 14
