Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Need help with with the right SSD Enclosure/Adapter
I need help with hardware compatibility for an SSD enclosure. The one I bought isn't correct, though the listing said it was only either 2.5 or 3.5. This is what I bought: https://www.amazon.com/dp/B0C73VYQCW?ref...
If it is right I can't see how it fits. Can you please point me to the right one, maybe just an adapter since I won't need durable use. Thanks for your kind reading.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The storage drive in the Retina 2012 15-inch MacBook Pro is not a 2.5 or 3.5 inch drive, its a specialized blade SSD. This is the enclosure you want (as far as I know they're only made by OWC).
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Will do Zach. Many thanks!
door
Voeg je antwoord toe
Pamela Wilson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 85
