Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
20 Vragen Bekijk alle
Why is my phone overheating?
My iPhone 7 plus overheats, and doesn’t hold a charge well. The battery max capacity is 82% It gets really hot in the area under the camera after mild use or charging. I found a few posts about this from several years ago, but they all had different answers. Is it a problem with the battery, or the CPU, or something else? I have a replacement battery I can easily put in, so I’m apt to try that first. Thanks for your help!
Have a great day and God bless!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The battery is definitely the place to start, and given that you already have one replacing it as the first step is the right call. Generally if the battery health goes below about 85% then it's considered time to replace it anyway.
So yeah, put in the new battery and let us know what happens after that.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you! I’m going to put it in later today, after church, and I’ll let you know how it goes.
door
@prestontech Definitely think this is a good start. It could be the board but If you already have a battery, why not. When you say it overheats, does it actually give you temp warnings? Or it just gets very hot.
door
@flannelist It just gets hot, though not as hot as it used to. I’m starting the repair right now. I’ll let you know how it goes!
door
@flannelist I repaired the battery, and it seems to be better now. Thanks!
door
Voeg je antwoord toe
Preston Tech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 39
