Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
20 Vragen Bekijk alle
My horn doesn't sound why is that?
My car was in a flood and we serviced it and it runs pretty well but the horn doesn't work and i don't know why can anyone able to help
Is dit een goede vraag?
1 Opmerking:
it could be water damage to the wires
door
Voeg een opmerking toe
1 Antwoord
@nazarhakeem check the horn itself first. Just apply some voltage directly from the battery and just touch the connectors on the horn. If the horn now works, you know the issue is with the wiring. Next check the horn relay and see if you have power on that. If so, you need to check your horn button and make sure that it works properly. We will need to know your exact model and year so we can assist you further with the wiring and locations of the components.
Was dit antwoord nuttig?
Voeg je antwoord toe
Nazar Hakeem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 12
