Ga door naar hoofdinhoud
The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
"Non-System disk" error - Keeps saying - HELP!
I fire up my PC. It sends me to the Intel BootAgent. Once it's done, It quits to "Non-System Disk detected" or something like that. Under, it says "Replace and strike any key to continue". I try it, but it fails to work.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Sounds like the System disk isn't detected. You can try re-seating the disk.
The disk may be corrupted or broken and need replaced though.
The computer may have an issue so you should try an external caddy for your drive to see if it works.
Guides:
HP COMPAQ 8200 Elite Ultra Slim Ultra-Slim Desktop Disassembly RAM SSD Hard Drive Upgrade Repair
HP 8200 Hard Drive Replacement
HP Compaq 8200 Elite Teardown - iFixit
Was dit antwoord nuttig?
Voeg je antwoord toe
Sebastian Towler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 74
