Ga door naar hoofdinhoud
Eighth generation of iPad, released September 18, 2020, available in 32 or 128 GB models. Model Numbers A2428, A2429, and A2430.
Is there a replacement for lightning port?
I tried looking through the guides but I am not seeing a lightning port replacement for an iPad8?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I expect most of the reason there isn't presently a Guide for this is because charge port replacement on most iPads is not as easy a job as other modular components.
The charge port (lightning port, dock, the list of names for it is extensive) flex cable is soldered to the motherboard in nearly all iPads, including this one. The part itself is available around the internet, and it is not tremendously difficult as far as soldering jobs in an iPad go,. But if you aren't familiar with soldering techniques, this might be better left to professionals.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jonathan Purvis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 176
