Ga door naar hoofdinhoud
Based on the fifth generation Legacy, the fourth generation Subaru Outback was introduced in April 2009 at the New York Auto Show, the fifteenth anniversary of the first Outback's introduction at the same event.
How do I replace a faulty head gasket?
How do Inrepair or replace a faulty head gasket?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Removing the cylinder heads on boxer engines while the engine is still in the car is possible but not practical. To get the best result, remove the engine from the engine bay and mount it on an engine stand. Then remove the cylinder heads and old gaskets. Clean the surfaces properly and then mount new gaskets, following the steps listed in a shop manual. Torquing the head bolts in the correct order and to the correct torque is critical. Then mount the engine back in the engine bay. It's a big job and not well suited for a DIYer who's never done this before
Was dit antwoord nuttig?
Voeg je antwoord toe
Tami zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 269
