Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Parts left after assembly
Hi!
I've got two unknown parts after reassembling my iPhone 4S (http://imageshack.us/photo/my-images/705...). Left part is some kind of antenna/ground stuff I suppose, right part is made from rubber material - found it while installing circuit board. Help me to put them into the right place.
Is dit een goede vraag?
Score -1
2 opmerkingen
Found where rubber part should be - side of circuit board where QR code label is. One part left...
door
Thanks, guys!
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The one extra part appears to be the pressure contact plate of antenna cap, that has screw hole for the top screw of the battery connector.
Was dit antwoord nuttig?
Score 2
The part on the left is a rubber bumper guard that goes alon the top edge of the motherboard to protect the LCD and digitizer cables from rubbing the edge of the board. It is not necessary to reinstall it but it is a good idea to because it is added protection and also takes some play out of the flex cables so they don't giggle around.
Score 1
I can confirm the part on the left does cover the antenna cap, the one on the right I also have laying around after re-assembly.
Voeg je antwoord toe
Dirty Spiv zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 914
