Ga door naar hoofdinhoud
De iRobot Braava Jet M6 werd uitgebracht op 12 juli 2019. Het is een robotmop die kamers in kaart kan brengen en vloeren reinigt door water te sproeien en te dweilen met een opzetbare pad.
Braava m6 not responding; not turning on and buttons don't do anything
I recently bought a used Braava Jet m6, and the robot does not respond. When I put the robot on the home base charging dock, for a few seconds, it lights up white and spins, and then it stops. When I press the "Clean" button, the robot doesn't respond. The same for all the other buttons. The wheels are not jammed and I already tried holding Clean for 30 seconds. It came with 2 batteries but they don't seem to work. The robot gets a little warm on the place where the cleaning pads are mounted. I have no idea what could be the problem, and I appreadiate any help I can get!!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
After a time my iRobot Braava m6 mop just stopped working all together.. I did the usual troubleshooting steps, namely: 1. Made sure everything was ready to go, clean and orderly 2. Removed the app (or widget) from phone then reloaded it. 3. Removed the battery waited 5 minutes and then reinstalled the battery. 4. Disconnected and reconnected to Wi-Fi. 5. I should mention that I didn't have any error messages. I called iRobot and they thought it was a dead battery so I bought a new battery ($90). Still no function. I ended up purchasing a new Braava m6.
Just a note: My m6 was probably 5 years old.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jonathan Trapp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 1,478
