Ga door naar hoofdinhoud
Released in June 2020. 10th generation intel device. Available in slate gray and orchid. Model identifier 82AS.
4 Vragen Bekijk alle
touch screen is not active
why is the touch screen not active after moving from window 10 to window 11
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Could you please provide a list of what you have attempted? (That way people do not suggest things you've already done)
Aside from the typical issue solvers:
- Check for firmware updates (and install if available)
- Restart the device
Have you tried checking to see if the driver is updated or active?
1. Open the Device Manager by typing "Device Manager" in the Windows search field
2. Expand the Human Interface Devices section
3. Click on HID-compliant touch screen
4. Click on Action in the top tool bar
5. Choose Enable device
6. Right click on HID-compliant touch screen to check that the device is working properly
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tempoyak Jambi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 47
