Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Can I replace the HDD in this iMac with a SSD?
Can I replace the HD in this iMac with a SSD?
Is dit een goede vraag?
Score -1
1 Opmerking
Should be alright if they both have SATA/eSATA connectors
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It can be done in your imac, you need a 2.5'' to 3.5 inch adaptor tough
get this adaptor
http://www.amazon.com/2-5-inch-3-5-inch-...
I suggest a good size SSD, a good one is 256GB or more, in fact the 256GB have gotten quite well priced
http://www.amazon.com/Crucial-2-5-Inch-S...
that's a 256, but there are other sizes
here is a install guide
[ongeldige handleidingslink]
As per storage space after, I suggest replacing the DVD drive and getting a 500GB HDD
get this adaptor and install the HDD in this adaptor to get more storage after the SSD is installed
http://www.amazon.com/9-5mm-Optical-Driv...
the drive i suggest for storage of your files(I have the 320GB version in my 2nd laptop too, this is a really good drive)
http://www.amazon.com/Western-Digital-Sc...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Does that adapter have something specific, or any one can do? The specific one you suggest cannot be found on europe amazon stores (the italian one, specifically). Can you suggest one that would be found there, or is it really not that important?
door
Voeg je antwoord toe
Jude DiGiovanni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 740
