Ga door naar hoofdinhoud
Subaru WRX. Non-STI model Standalone model from the Impreza.
Traction control light on-hill assist light on(off)
What I need to check or buy to repair it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here is an article from “myrandomtechblog” that explains one fix for the issue.
https://myrandomtechblog.com/automotive/...
It seems to cover what you are describing in the title and looks to be a relatively easy fix.
Apparently there was a Subaru recall back in 2019, but it’s probably a part that will continue to need replacing every so often unless an aftermarket supplier makes an upgraded version of the switch.
Hope this helps
Was dit antwoord nuttig?
Voeg je antwoord toe
Michael Williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 265
