Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Vraag afgerond
Black screen of mystery
So I had the famous coffe spill.
The laptop started with a nice chime, but the screen stayed black.
"Crap", I thought, and bought a new logic board and promptly replaced the old one.
Problem is, the darned thing still just chimes and nothing else.
I tried both a different lcd assembly as well as an external screen, same thing.
Ideas?
Is dit een goede vraag?
1 Opmerking
Try booting from Install CD/DVD run Hardware test.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If the coffee entered the machine via the keyboard, you may have shorted it out and need a new uppercase. The old logic board may be just fine. Examine it to see if the LSI dots have turned red or are still white.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
The spill mainly affected the ports on the right side, not inside the keyboard as far as I could tell. But I'll pop it open and have a look.
Can a faulty topcase cause the screen not to work?
door
topcase doesnot effect the lcd .
door
OK; so I bought a new board *again*, and it still don't work. I got a flicker on the second LCD assembly, but then it failed again.
door
try with the flash to the screen. may be its just only the back light problem due to spillage . dismantle the laptop to check the damage to the logic baord. if logic board suffer spillage damage then clean it properly and leave it for few hours . then power up the laptop to check its now working. if still not working then you have to go to repair shop for repair the logic board. thnx
Score 1
5 opmerkingen:
The board is new.
door
new board doesnot mean that it doesnot have any problem. if it is not giving any video to external display also then you logic board fried . its a problem of graphic card or something blown on the logic baord. put the pictures of logic board to check from both side .
door
Thanks Simran, you are probably right. I may have gotten shafted on the new board.
door
pls accept it thnx if solve
door
I’m having the same issue, except I only get a chime after ALL POWER is cut from the system. This either means removing the battery, or just waiting for it to die so it’s like it’s not giving any power anymore, then it’ll chime, but only a white screen remains, then every subsequent start starts to a black screen. Internet recovery works, but only when the chime works, and sometimes I can get the boot picker to come up but it doesn’t really do anything, it fails to set a boot volume, something I found out when I tried the same thing through internet recovery. I am unable to do much else via internet recovery, however, as somehow the INTERNET doesn’t WORK while in internet recovery, as wifi won’t turn on and Ethernet appears to do nothing, which doesn’t make any %#*@ sense because I got this to come up through the INTERNET.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 749
