Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
Two rows of touch do not work after repairing Home button
Hi,
The home button on my iPod touch 4g was stuck down so I opened the case to fix it. Now it works fine but when I turned the iPod back on, I realized that one row of touch did not work. It then expended to the last row as well after I tried to reseat the LCD cable. Then I disassembled the iPod some more to disconnect the digitizer completely and reconnect it. Same thing. The two last rows don't work. The digitizer cable does not seem damaged and I was VERY cautious during the whole process. Is it possible that I broke the digitizer itself? Is there something else I should try? If I order a new screen will it fix the problem?
Is dit een goede vraag?
Score -1
2 opmerkingen
I booted the iPod in recovery mode. I'm performing a full reset at the moment and if it doesn't work, I buy a new LCD+digitizer hoping that it will work...
door
Same problem after full reset. I bought a new screen on Amazon. We'll see how it turns out...
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Buying new digitizer could fix the issue.
Was dit antwoord nuttig?
Score 2
Try to clean contacts of digitizer with alcohol, I did it with my iPad and it helped)) but be careful
Voeg je antwoord toe
Matthieu Pepin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 434
