Ga door naar hoofdinhoud
Kleine volautomatische koffiemachines van Melitta. Deze handleidingen kunnen ook helpen bij andere Melitta-modellen en bij volautomatische koffiemachines van Nivona, Siemens en Miele - de modellen hebben een vergelijkbare structuur.
19 Vragen Bekijk alle
Brewing unit won't go back in
The brewing unit of our Melitta Caffeo Solo did not going back in.
I found mentions of the motor not being properly aligned.
The official FAQ states: The motor might not be in the correct position. Check if the water tank is filled and if the drip tray is in place. Turn the appliance OFF and then ON again. Then simultaneously press the button for My-Coffee and the on/off button for more than 2 seconds. The motor will move into the correct position. Insert the brewing unit again and check that it is correctly locked in position.
However, this proposed solution did not reset the motor position in my case.
I found that the locking handle of the brewing unit moves a metal lever.
This metal lever engages a button in the machine.
By carefully pressing this button (i used the handle of a small spoon), the motor reset to the correct position.
Long story short: I don't have a question, and just wanted to post this here for future reference.
Is dit een goede vraag?
Score 2
1 Opmerking
perfect solution - most grateful.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Was dit antwoord nuttig?
Score 2
Yes, this is a good try! If it is not successfull, there is one more option which acquires plenty of work:
  • Open the device and the drive. Connect 12 V to the motor leads until it reaches the right position.
If it happens more often, the gearbox will have to be opened anyway.
Score 2
Thank you so much. You helped me today.
Voeg je antwoord toe
bfdb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 121
Altijd: 560
