Ga door naar hoofdinhoud
No power after it crashed.I replaced a new ram and harddrive but not?
No power even after placing a new ram and harddrive.Can you kindly advise?
Is dit een goede vraag?
Score 1
3 opmerkingen:
Hi @ben74600
Which model is it?
You selected a G5 and now a G8 in a new question?
Did you remember to disconnect the battery from the motherboard this time, before removing/replacing ram and HDD? ;-)
Does the laptop indicate that the battery is charging when the charger is connected to the lapto
door
Mine indicates it's charging then when I press the power button the power light turns on for a few seconds then turns off nothing displays on the screalen screen no fan noise no power on the drive
door
@nash49219 start a new thread - it isn't the same problem. Then you can rate any answers.
door
Voeg een opmerking toe
1 Antwoord
I assume by "crashed" you are referring to a HDD failure, right?
If so, I don't know why you would replace RAM, unless you upgraded it.
Even so, those replacements are simply unplug and replug.
Therefore, somewhere in that process, something else got disturbed. Recheck all the cabling.
OR, you did the replacement without removing the power - battery and adapter - and shorted something out.
In that case, you now have a bigger problem that isn't going to be easy to fix or cheap to get fixed.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 275
