Ga door naar hoofdinhoud
Model A1001 of A1025 / 667, 800, 867, of 1,0 GHz G4-processor
Won't boot passed blue screen?
Can only get in single user mode.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try booting in Safe Mode by holding down the Shift key. What system are you running. Start up from the installation disk by putting the disk in the CD drive and holding down the "C" key while hitting the start button the run Disk Utilities and see if you can repair the system.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Too fast for me--like the idea of booting into the safe mode. Ralph
door
Het nuttigste antwoord
If possible boot with your OS disk and run disk repair until it finds no problems. With luck that will clear the problem. You should do a backup of your data first because you may end up needing to format and reinstall. Backup first and then repair. Good luck. Ralph
Score 2
1 Opmerking:
Good idea ;-) +
door
Voeg je antwoord toe
Ron zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,448
