no master login set but still asks for it
this machine has no master login but the finder is flashing at me to login in and I do not have a login name or password
Is dit een goede vraag?
What you said in your second response is different than the question. Are you getting a folder with a question mark or a log in screen asking for name and password?
Was dit antwoord nuttig?
A folder with a question mark means the computer can not find a system folder. If this is the case then insert your system installation disk hold down the "C" key and see if it will start.
A question mark usually means the computer can't find a bootable drive. Can you boot the computer from your OS disk? If you can select disk utilities and run disk repair. If you are unable to do that you may need to reformat the drive and reinstall your OS. Ralph
+1 to Mayer for his quick and I think correct answer. Ralph
Same to you Ralph +
Have you tried using your account name
(for example your account name is usually your full name, can also be found in the accounts section of the system preferences, Not your short name which your home folder will have)
as for a password, try just logging in without a password.
Thank you so much for your answer but still not working i do not have access to get into lap top finder has a ? mark not sure what to do next pam
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 552
