Ga door naar hoofdinhoud
Repair guides and support for LED, LCD, HD and other Vizio TVs.
20 Vragen Bekijk alle
Vizio M55-C2 No Video & Flashing Status Light
I have a Vizio M55-C2 TV with no video. The status light will immediately white when I power on the TV but when I press the power button it does not turn on. The light eventually will dim and then turn off temporarily and then it turns on again and starts flashing white. Still no video or any other sign of life besides this. I attached a video of the blinking lights.
I have tried unplugging it and holding the power button for 30 seconds and then plugging it back in to no avail.
Board looks good to my novice eyes..
What could possibly be wrong here? I read up on similar issues with Vizio TVs and a common similarity is that the power light will turn on bright at first and then fade off. Mine then comes back on and starts blinking after powering on and fading off. It’s making me think power supply issues possibly are the problem
Is dit een goede vraag?
3 opmerkingen
I ordered a new power supply. It’ll be here by saturday. Hopefully this fixes the issue
door
Power supply did not fix the issue. Ordering main board next
door
@tronke have you disconnected teh ribbon cables that go from the T-con board to the LCD driver boards? First one, then the other one. Let's see if that changes anything.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It ended up being the main board. Power supply was fine.
Was dit antwoord nuttig?
Voeg je antwoord toe
tr121 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 78
