Ga door naar hoofdinhoud
ThinkPad L13 (13”, Intel) Laptop Thin and light-13.3" display
Why my laptop won't charging?
My laptop won't charging. Charger adapter not problem, because when i use the same charger adapter to another L13 thinkpad it work properly.
When i plug the adapter to port usbc led indikator not turn on.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@denykuswandi could be a lot of things and you will have to do a deep dive to do a bit more troubleshooting. You'll have to disassemble your laptop and check the USB-c port on the motherboard, check the USB controller and definitely check the battery. A failed battery does not get charged. Get an ammeter and see how many amps your laptop draws when it is plugged in. If it does not draw anything, or just minor amperage, it is most likely your battery.
Use the Lenovo Thinkpad L13 Hardware Maintenance Manual and we need to know what motherboard your computer uses. If it is a L13 1st gen, it should be a Wistron 18834-1N It'll be printed on the backside of the board.
Was dit antwoord nuttig?
Voeg je antwoord toe
Deny Kuswandi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 252
