The space to insert a disk no longer works
The space to insert your disk no longer works
Is dit een goede vraag?
Check in the cartridge reader to see if anything is bent or if it’s dirty. Clean it with isopropyl alcohol and try to get any pins that are bent back to their correct position. Also make sure your game’s contacts are clean. If that doesn’t work then you should probably check the board for corrosion and clean that up.
Hope that helps!
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 13
