Ga door naar hoofdinhoud
Apple's nieuwe format voor de 14 lineup bevat een 6.7-inch OLED-scherm—zoals de Pro Max—maar ook dezelfde features als de iPhone 14, met een dubbele camera-setup en de Bionic A15 chip met een 5-core GPU.
20 Vragen Bekijk alle
What might be the possible soln to this log below
Afbeeldingsinhoud bekijken:
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I currently have this same issue. 0x400000 is for the wireless charging coil flex. My rear cameras and flash are not working either, do yours? I have tried replacing the wireless charging coil already and it did not fix this kernel panic.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Unfortunately yes I have the same problem , no flash and no back panel. I don't know what to do to make it work . I haven't found a solution yet . I tried to put an aftermarket rear panel on it , but it was probably the panel that was faulty . Did you try to fix it with a factory part ?
door
Yes I ordered a new rear camera and wireless coil to see if either part was faulty and causing the others not to work. I also tried 2 different back panels and none of the parts fixed the issue with panic. Im starting to think that its not the camera or the wireless charging flex and actually an issue with the logic board that has disabled those circuits. I have done multiple restores even with the new parts installed and that didn't fix it so Im out of ideas.
door
Voeg je antwoord toe
Ernő Németh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 83
