Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
How to fix a Trackpad with no click function? (2009-2015)
I have an issue with a 2009 MBP A1278 the trackpad has no click function.
It is a total fresh install (Dosdude Catalina Patch) on a Samsung EVO 840 SSD but I know it is not an issue with the patcher software. I have swapped over 2 known working trackpads but there is no change. Everything is spotless clean. Their are no issues with the KB or other internal connections or components as everything is running very smoothly. I can only assume it is something with the silver adjuster on the casing as that is the only thing that hasn't been replaced as I don't think that can be the problem? The click function was working fine AFAIK the last time I used the machine, The trackpad has a good feel and a nice click tap sound. Asking the expert @danj on any suggestions?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Review Step 30 in this guide to adjust the click plate MacBook Pro 15" Unibody Early 2011 Trackpad Replacement that’s assuming the battery is not puffed up!
Was dit antwoord nuttig?
7 opmerkingen:
The Battery CC is 180 Normal condition and no swelling.
I have tried to adjust the silver diamond shaped screw but it is stuck solid.... having compared it to other cases and it looks fine.... It doesn't work even in recovery mode. I think it is highly unlikely a board issue, the connector is fine, maybe only ever once or twice removed when I have worked on it.... Will update.
door
@livfe - The click plate adjustment is the issue. This series uses a simple blister switch which you can see in the triangle cutout in the middle the set screw adjustment sets when the blister is depressed causing the click action both physically (feel) as well as electrically. You’ll need to use some solvent if the screw is locked. I also find driving in out going forward often is more successful than trying to back it out, but the trackpad will need to be removed first to offer the clearance.
door
@danj Yeah I got it free and adjusted it and it seemed to have done the trick.
But then this happened to my struggling 2009 A1278 which had the stage lights > no lights so I cannot test it right now lol
door
@livfe - Thats a different issue which needs a different Q!
We need to keep things organized otherwise we all get confused. Clearly a different issue right? 🤷‍♂️
If your set on this one please score and accept it as thats my reward!
door
@danj Dan, I adjusted the screw and I cannot test it because the lights went out totally when I restarted it .... what am I supposed to say? Anyway this 2009 is done. Not spending anymore time or money on it, one thing after another going wrong on it.
door
2 commentaren meer tonen
Voeg je antwoord toe
livfe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 253
