Ga door naar hoofdinhoud
De mainstream iPhone 2019 van Apple, die 20 september uitkomt, heeft een 6,1-inch lcd-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
Random restart cpu 2 caller
Help! Iphone 11 restarts randomly
What is that?
Service center doesn’t know that problem
As a decision the suggested me just to change the battery, but that looks like the lottery
  "build" : "iPhone OS 16.0.2 (20A380)",
  "product" : "iPhone12,1",
  "socId" : "0x00008030",
  "kernel" : "Darwin Kernel Version 22.0.0: Tue Aug 16 20:50:57 PDT 2022; root:xnu-8792.2.11.0.1~1\/RELEASE_ARM64_T8030",
  "incident" : "4B22DF67-3C69-4679-9A80-DCD915AA072F",
  "crashReporterKey" : "0afec6380865981fc6cb2aa69465b558f3bfc015",
  "date" : "2023-11-25 12:20:45.55 +0300",
  "panicString" : "panic(cpu 2 caller 0xfffffff02646c38c): \"AppleSocHot: Hot Hot Hot (893D0DF0\/5575 89180EBC\/5893 09670D3C\/0 886D1268\/7362 81A332F9\/20389 88D71021\/6451, Ids 23\/7\/23\/16\/0\/4\/0\/0\/0, Perf 100\/100)\" @AppleSocHot.cpp:694\nDebugger message: panic\nMemory ID: 0x1\nOS release type: User\nOS version: 20A380\nKernel version: Darwin Kernel Version 22.0.0: Tue Aug 16 20:50:57 PDT 2022; root:xnu-8792.2.11.0.1~1\/RELEASE_ARM64_T8030\nFileset Kernelcache
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Your device is overheating to the point of a forced shutdown to prevent damage. ⚠️
" AppleSocHot: Hot Hot Hot " is the ios equivalent of tjmax on windows
Non repair Troubleshooting
Avoid using the device while charging.
Remove the case
Avoid games and apps that draw lots of computing power
Avoid having too many apps open at the same time.
Look into background battery usage to help identify which processes are using the most power. The power draw will be directly related to the heat produced.
Repair trouble shooting:
First, I'd back up, and factory reset the device in case some software misuses system resources
I'd look into the condition of the battery.
Check your liquid damage indicating paper stickers on the back of the screen in the sim tray and inside the device by the charging port and camera cluster.
Then, I'd check the logic board under a thermal camera to identify shorted or damaged components causing excess heat.
Adding thermal paste to the logic board is a viable option if you can't identify a clear cause for thermals to be high.
There are also active cooling accessories like the razer phone cooler you might see benefits from.
Hope this was helpful
Was dit antwoord nuttig?
Voeg je antwoord toe
Peter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 557
