My fingerprint sensor is not working
Fingerprint sensor not working, The test said: CALI test result: false. What happened to it?
Is dit een goede vraag?
Have you replaced the display?
According to reddit you'll need to recalibrate the sensor if you have.
I'd also recommend cleaning the scanning area with a Microfiber cloth to ensure accurate reading.
"To access the calibration menu you need to:
Go to settings > About phone > All specs > repeatedly tap Kernel version until the calibration menu appears > tap the menu button in the top-right corner > Additional tools > 6. Fod fingerprint calibration.
Follow the steps on the screen. The first test is to hold a white cloth/paper over the fingerprint sensor. The second test is a black cloth/paper. The third test, just use your bare finger.
If it says "Test successful" at the end, the fingerprint sensor should be ready to use. If the test fails, try again. I read a forum post where someone had to try three or four times before it passed."
If recalibration doesn't fix the issue I'd recommend a visual inspection of the internal hardware.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 123
Altijd: 241
