Ga door naar hoofdinhoud
Krachtige tabletcomputer van de 3e generatie, uitgebracht door Apple in oktober 2018. Modellen A1876, A2014 en A1895.
Ipad not recognize wired Headphone
My Ipad not recognize wired Headphone
I change usbc port but not fix it
Any idea please?
Is dit een goede vraag?
2 opmerkingen
Which headphones are you using? Does it recognize other devices connected to the USB port (like an HDMI adapter, or USB drive)?
door
@flannelist My iPad recognize only charging
No headphones no usb drive
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It is worth making sure your iPad is fully up to date, or processing a full reset to see if that helps if you haven't done this already, but this sounds like a board level issue to me.
The iPad Pros are more similar to a MacBook in terms of their USB function they contain a proper USB controller, (that is also involved in charge function) that could have been damaged. They also contain a variant of the "Tristar" chip that is often damaged in iPhones or older iPads. In all possibility, one or both of these chips will need to be replaced to restore function.
Unfortunately it requires some advanced soldering skills to replace these, but it's a pretty common fault across the board. Image below is from the equivalent iPad Pro 11" but concept is the same.
Afbeelding
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
M al zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 60
Altijd: 1,196
