Ga door naar hoofdinhoud
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
MacBook doesn’t charge
The MacBook doesn’t have any sign of accepting charge from the original charger (80w). When I plugged it in to a different charger (60w) it said it was charging but then in the morning it was still dead. It’s charged off a 20w charger before and I also tried the only other charger that’s USbc that I have which is a 30w charger
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did you try a second USB-C cable? Make sure it’s designed to charge as some don’t work fully.
Give the systems age you may need a new battery and/or the systems charging logic needs repairs.
Was dit antwoord nuttig?
3 opmerkingen:
All of the chargers were used with a different cable and they were all charging cables
door
@sambaumann - I’m assuming you also tried the other ports just in case one side wasn’t working. At this point you have a logic board issue within the charging logic.
There are techs with deep micro electronics skills who can fix your logic board otherwise it’s replacing it which can get expensive depending on the config.
Where do you live? Country and nearest large city, maybe we can aim you to someone to help you.
door
I checked the price of logic boards and the price of repairing them and I think it would be better just to get a new Mac as the one I have is extremely old and will probably make me end up spending more money repairing it than if I just bought a new one
door
Voeg je antwoord toe
Sam Baumann zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 63
