Is it possible to replace the WIFI IC chip?
The Wi-Fi chip on the iPad Pro M1 is failed due to a short. (I checked it clearly through the logic board check. A short circuit between GND and VCC occurred inside the chipset.)
So the Wi-Fi chip needs to be replaced, and the iPad needs to change the Wi-Fi address in NAND when changing the Wi-Fi chip.
But from what I heard, no NAND programmer can perform the Wi-Fi address Unlock on the M1 NAND. Is this true? Is it impossible to repair it at all?
Is dit een goede vraag?
