Ga door naar hoofdinhoud
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
277 Vragen Bekijk alle
Broke some components while attempting battery swap
Broke some components located on the left side of the logic board (with the touchpad facing towards you) while replacing battery on my MacBook Pro 2017 With Touch Bar A1706. Please help me identify the components and their purpose so i can get them repaired. Kindly see attached photos.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This doesn't look like a tremendous amount of damage and it's quite common for these to get nudged during the course of repair.
The chip is a temperature sensor intended to monitor air flow temperatures on the right side of the board and the right side thunderbolt controller. It looks like there are a few traces pulled up from the circuit board, which will specifically need repair.
For reference it is a Texas Instruments TMP461 if you want any of the specifics, but I don't see any damage to the chip, so it's likely to be perfectly fine.
This probably won't affect the ability for your Mac to power on, but it might run very very slow, since this temp sensor is unlikely to work properly in its current state.
Otherwise, it looks like a capacitor got nudged. This is part of the power circuit for the built in SSD. There are many other capacitors on this same line, so its presence is not 100% needed, but it's along the edge and would be easy to replace. The schematics call for a 22 µF 10V capacitor in a 0603 package.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Waleed Pahe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 17
