Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
20 Vragen Bekijk alle
Switch not outputting via HDMI
My Switch stopped working with my TV overnight - there was no power outage or anything, it just stopped displaying anything via HDMI.
I’ve seen similar threads where users suggested power cycling the TV, trying different ports etc. but that doesn’t seem to be the case here since I’ve tried it on another TV and my PC monitor with no success. I’m sure that the dock is okay - a different console works perfectly fine on my dock while my Switch doesn’t work with a different dock either, I’ve also tried a USB C hub with HDMI output which didn’t work too.
Is there anything else I can try before sending it off to a repair shop? My console is already nearly 7 years old (Mario Odyssey version) but works perfectly fine, apart from the TV output. If the console is indeed faulty, what could be the cause? I’m guessing it’s going to be a way more serious repair than just replacing the USB C port since it charges without issues.
Is dit een goede vraag?
Score 1
8 opmerkingen:
Have you tried a seprate HDMI cable for that port?
door
Both the original Nintendo one, other cables that work with my Xbox for example and even a completely new one - no luck.
door
Have you tried a factory reset?
door
Yup, didn’t help either
door
Maybe a solder joint cracked? Take a look at the charging port and P13 chip, reflow them if you're able. (The port has extra pins tucked under it, so it requires hot air)
door
3 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
I would check for shorts along the m92 chip and the video chip. If any of the capacitors are shorted that means the chip has a short which could cause this. I think it’s more likely the video chip since I believe that’s what determines if the usbc acts as a video output or a charger. I’m not entirely sure because I haven’t been working with switches for too long but that is what I would recommend. Hope you can get it to work!
Was dit antwoord nuttig?
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 246
