Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Why is my MacBook Pro beeping after replacing the battery?
I just replaced the battery in my MacBook Pro 15" Unibody Mid 2012 with the one from ifixit. I have tried plugging in the laptop to charge and calibrate the battery but the laptop is now making a 3-beeping sound that does not stop. The orange indicator on the cable suggests the battery may be charging, but I am wondering how to solve this new beeping noise (has never happened before). Other things I have read suggest maybe it has to the with the RAM but I'm not sure. Thank you in advance to anyone for your help!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
What is the beep pattern?
Review this to figure out what’s needed If your Mac beeps during startup
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi Dan,
I ended up taking out the RAM and putting it back in even though it looked fine and it seems to be working now. Maybe it just needed to be reset after the battery switch for some reason. Thanks for your help!
door
@vjlombardo - I’ve had to do that a few times too!
Happy you’re set, don’t forget to accept the answer, Thanks!
door
Voeg je antwoord toe
Vince L zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 141
