Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Can I replace rear glass using a donor phone?
My brother has two of these phones, both broken in different ways. One has shattered rear glass and the front screen is falling off. I think I can easily sort the front screen issue but I wondered about the rear glass. The other phone has intact rear glass and I wondered if I could use it as a donor phone or if the glass will always end up broken in the removal process.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
While you cannot swap the back glass you can swap out the rear housing between them. You can follow the iPhone 8 Plus Lightning Connector Assembly Replacement to get there.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Andy Barratt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 69
