Ga door naar hoofdinhoud
Apple's kleinste iPhone 14 is op 9 september 2022 uitgebracht en bevat een 6.1" OLED-scherm, een geavanceerd dubbel 12 MP camerasysteem, en een voorste camera met autofocus. Dit is de opvolger van de iPhone 13.
20 Vragen Bekijk alle
Cable between battery and cam
Hi to all,
I bought a used iPhone 14 with already replaced battery. Sometimes it is charging correct and sometimes it paused because of hot battery. But it is not hot! Not even warm. I already ordered a new battery from here (but not delivered, yet).
I opened the iPhone to have a look and I found some scratches on the cable (or thin, tiny, black board) between battery and rear cam. It is connected beside the wireless charging cable.
I think it get those scratches from getting the old battery out of the phone.
Is here a temp sensor on this cable and make this strange problem? What is the name of this cable? Can I buy a replacement here or somewhere?
Regards
Patrick
Is dit een goede vraag?
Score 1
3 opmerkingen:
Hmm, I think it is just a thin, black metal separator. No cable, no sensors on it. Just metal separator mounted to the frame.
I hope it’s a bad replacement battery and it’s done with a new one from here. Never hat an issue with a battery from ifixit since iPhone 4s.
door
You are correct, that is the walls of the battery bay
door
It only thinks to heat up. This phone is still cold. I know how a warm iPhone feels and this one isn‘t even a littlebit warm. I will try the new battery and if the problem still exist I‘ll try the charging port. Thanks.
door
Voeg een opmerking toe
1 Antwoord
It might not be the battery itself, do you know if there was any thing such as water getting into the charging dock or ANYTHING like that. Try replacing the charging dock new charging dock (I might make a guide soon). And if that fails you have a fault logic board that requires micro-soldering :(
Good job trying to fix it though and noticing that imperfection!
Replace a lightning connector assembly compatible with the iPhone 14. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-03758. Afbeelding
Product
iPhone 14 Lightning Connector Assembly
$72.99
Was dit antwoord nuttig?
4 opmerkingen:
I don‘t know why battery was replaced or who did it.
Inside the iPhone it looks very clean. No hint for this problem.
Replace charging port because of battery to warm message?
door
Yes, there is a tempature sensor in the charging port and if the phone only heats up during charging then there is good evidence that it might be because of that
door
Today the new battery arrived. I could charge it from 70% (it came with 70%) to 100% with an old apple 10w charger (usb-a to lightning) in 1 hour without any temp warnings. I hope the problem is fixed with the new battery. We will see.
I know, why I only replace iphone batteries by myself and only with ifixit batteries! Thanks for good quality since years.
door
@paettes increadible to hear, es ist sehr gut du kannst reparieren ein Handy und est ist nicht heiß (sorry for my terrible german I'm only in my second year of learning)
door
Voeg je antwoord toe
Pättes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 100
