Ga door naar hoofdinhoud
ATX Mid Towers have the same general build and parts as other mid size computer towers
Message every time the PC is turned on
Hi, every time I turn on the PC this message appears "Please enter setup to recover Bios setting.
When Raid configuration was bulit,ensure to set SATA configuration to RAID mode.
Press F1 to run SETUP."
What should I do to solve this problem every time I start the PC?
Update (04/11/24)
Solved I changed the bios battery and solved the problem.
Thanks for the reply.
Is dit een goede vraag?
Score 1
1 Opmerking
Hi @ale60137,
What is the make and model number of the PC or the motherboard if a custom build?
Was the PC setup to be used in a RAID configuration or not, before this problem occurred and if so was it working OK?
Was there any general power failures to the premises where the PC is located, when the PC was turned on and working, just before the problem occurred?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check BIOS battery, it needs to be at least 3.6
Was dit antwoord nuttig?
Voeg je antwoord toe
ale zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 126
