Ga door naar hoofdinhoud
Repair and disassembly information for Logitech's G Pro X Superlight wireless gaming mouse. Identifiable by model number MR0106. Released in December 2020.
5 Vragen Bekijk alle
Why is it not charging?
When ever I plug in my superlight to charge it and take the charger out after a while it shows a red light and turns off a couple seconds later
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
This is usually one of two things,
The charge port, this can easily be ruled out by being able to use the mouse wired.
The battery, it may have degraded for various reasons however if the mouse indicates its charging when plugged in and when unplugged it dies, its most likely the battery is no longer able to hold a charge.
Was dit antwoord nuttig?
I have the same problem but when I plug the charger led is off. My mouse is off I can’t use it , already change the cable but do not match.. can you help me please? 🙏
Voeg je antwoord toe
Rian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 205
Altijd: 2,728
