iPhone 14 Plus Kernel panic
I have an iphone 14 Plus that is constantly kernal panicing. It has not been cracked or water damaged. The rear cameras and flash do not work for some reason. I have checked the connectors and have attempted to restore the device. However, the device fails to restore unless I unplug the flex cables except for the dock/battery/screen. I have attached the log, any idea what is causing the panic?
Is dit een goede vraag?
2 opmerkingen
Here is the full panic log. https://pastebin.pl/view/0abc132e
door CAB
Using Apple's Mobile Resource Inspector diognostics tool only showed that the rear cameras could not be detected. Will the device keep Kernel panicing if the camera is faulty/unplugged? The flash doesn't work either but wireless charging and the mic works, could the flash just be disabled by iOS?
door CAB
