Ga door naar hoofdinhoud
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
Mac Mini 2014 missing bottom cover. is this a problem?
I have obtained a mac mini 2014 that is missing the plastic bottom plate cover. Is this a problem? Does this block airflow, and if so, would this be mitigated by adding feet to the base of the mac to give raise the device a little to allow air circulation? are there any other issues that will need to be worked around?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I'd recommend adding the feet onto the Mac as it would allow for improved airflow into the device. But other than that I don't think it should be too much of an issue.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
It might be just worth the expense to replace it here's the needed part Mac Mini Bottom Cover (used) $11 USD
door
Thanks Dan. I had searched for these online but had not found one with reasonable postage to Australia. I have bought this one as both the price and postage were reasonable.
door
Voeg je antwoord toe
James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 29
Altijd: 392
