Ga door naar hoofdinhoud
Replacing the Audio Assembly
I have a customers 4th gen nano, there is no sound coming from the audio assembly, so naturally, i would replace it... but in the 4th gen nano it is soldered onto the board, i just want to know if anyone has ever successfully soldered a new one on, or fixed the old one, ie..replacing the pins inside it or whatnot. any ideas?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I think you will need an all-new board as the soldering is most likely surface mounted; making it incredibly difficult to solder.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
i received replacement parts from china, they have the setup done, but yes i am afraid to resolder or reglue... until i hear someone has done so otherwise
door
this is true, soldering a headphone jack on one of these is work for robots.
door
my ipod got the problem too,
i am looking for the parts in china,
just wanna know did u did it eventually??
door
Voeg je antwoord toe
Ptr702 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,488
