Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Grand Prix kreeg in 2004 een update op een herziene versie van het GM W-platform en werd op 7 februari 2002 op de Chicago International Auto Show onthuld als de Grand Prix G-Force Concept.
Anti theft system/Lock system, stuck in learning mode
So I got an 05 grand prix, the theft system is in learning mode and I can start it, though I only have the valet key for it, I assume if.i just do the learning procedure it will take it out of learning mode though, I haven't tried it cause I'm not sure if my key will start it if I do and I'm not ready to pay for that headache , unless itl be fine if I do take.it out of learning mode, also having issues with the door lock switches only locking the doors and the trunk release won't work either cause it's part of the lock switch, but putting it into drive locks and putting it into park unlocks them just fine.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
If you do take it out of learning mode and your keys can’t start it use this method
*****THIS IS A COPY*****
Put the key in the ignition and attempt to start the car, the "Security" light should go on and the car won't crank. Don't move the key to the "off", leave it on.
  1. Leave the key in the on position for around 10 minutes, the security light should eventually go out.
  2. Turn the key to "off", wait 5 seconds, then attempt to start the car. If it starts, you're done! If it doesn't start, to back to step 1 and try again. You may need to repeat this process up to 3 more times to get the car started.
Was dit antwoord nuttig?
3 opmerkingen:
I don't know how to get it out of learning mode though.
door Deel
The security light never goes out I waited for a full 30mins even
door Deel
@jameswiencek I don’t know then I’m sorry
door Deel
Voeg je antwoord toe
James Wiencek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 1,090
