Ga door naar hoofdinhoud
Geïdentificeerd aan de hand van het modelnummer: JBLLIVE660NC. Het is een draadloze over-ear hoofdtelefoon die in 2021 werd uitgebracht. De JBL Live 660NC is een Bluetooth 5.0-compatibele hoofdtelefoon met Adaptive Noise Cancelling-technologie, JBL Signature Sound en een batterijduur tot 50 uur.
The volume up button is not clicking, every button not regestering
Every function but the power button doesn't work, volume button cant be pushed down.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
you can try if your volume buttons aren't working:
  • Restart your phone: Restarting your phone can help restart your phone's software and background services.
  • Check for physical damage: Look for dents or scratches that could be preventing the button from working.
  • Clean the volume button: Sometimes a button gets stuck because it has collected dust and debris.
  • Use soft keys: You can use soft keys to increase and decrease the volume.
  • Create a sound widget: This allows you to adjust the volume on your home screen.
  • Reset your phone: A full reset might work if your volume button stops working after an app download or a jailbreak attempt
Was dit antwoord nuttig?
Hey there,
I got the same problem with the + button not clicking. The reason may be, that the micro switch had seen overload/too strong push action. I solved it like that: Disassemble the cushion and open the housing. Then open the affected micro switch by genly (!) bend away the metal on both sides. Then bend the switch body a bit to the inside of the housing. Be careful with the soldered pins. Then you should be able to get out the little plastic push button and a tiny metal plate. It's like the clicking/jumping toy-frogs. This only works when it is convex to the push button side. If it's not, try to bring it back to such a shape. Mine wasn't 100% and doesn't sound like the others, but it works again :-) Good luck!
Voeg je antwoord toe
carter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 1,598
