Shutter curtain only opens on slow speeds up to 1/30s.
Shutter curtain does not open from 1/60 and faster speeds. Shutter mechanism seems to fire at all speeds.
Is dit een goede vraag?
This camera uses a curtain focal-plane shutter. The bearings often need some lubricant as well as the gear train.
The trick is getting to them to clean things and then lube.
Was dit antwoord nuttig?
I can't say definitively that your camera doesn't have other problems, but I used to do this kind of work. You have a timing problem. If you got no exposure only at higher speeds than reported, I'd say your second curtain is overtaking the first curtain, a rather common calibration problem. This is generally a pretty accessible adjustment, although you would still need test equipment to do it. But for the SLRs I've seen, 1/30 is the slowest speed at which the first curtain opens all the way before the second curtain starts. I don't see how the second curtain could then overtake at 1/60. This means you have a problem with the shutter escapement, which is a bigger deal.
Camera disassembly is a pretty delicate operation. I don't know this model, so I don't know how much disassembly is required to fix it. You need to measure curtain speeds, which requires expensive equipment you don't have, in order to determine the exact problem.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 32
