Why dose my 2006 Camry not starting
I had to replace my timming belt and my alternator but now am getting lights and evrything but my car wont turn over and whrn do try there is no noise at all coming from motor
Is dit een goede vraag?
Paul, Are you still having this problem? If so, recommend going back to the basics and checking fuel, battery, starter, etc. If no crank, can you still hear the fuel pump turn on when turning the key to ACC? If not, check the fuel pump fuse. If so, check the battery. If all of that is good, check the starter, including if power is going to the starter.
Was dit antwoord nuttig?
Are the lights on then probably not batt........if just click no vroom the starter and if it dies every time you turn it off your alternator
.........gl
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 36
Are you sure you didn't mess up with the timing when you changed your belt?
door Vertinhol
yes just took the old one off and put new one straight on
door Paul Nicholson
